sunny5280 Posted May 25, 2017 Share Posted May 25, 2017 I just purchased a BlackVue DR650S dual channel dashcam for my 2005 Outback XT. Does anyone have any experience with installing this, or similar, dual channel dashcams? If so are there any gotchas I should be aware of when I go to have it installed? I don't have any experience with these devices so all information anyone can provide would be helpful. Link to comment Share on other sites More sharing options...
freaksavior Posted May 25, 2017 Share Posted May 25, 2017 Well, it says dc input is DC 12V – 24V so you could just tap straight off of a turn on wire or a constant source if it has motion. The dome light works well for this. Link to comment Share on other sites More sharing options...
sunny5280 Posted May 25, 2017 Author Share Posted May 25, 2017 Thanks for that idea...I hadn't considered using the dome light. Link to comment Share on other sites More sharing options...
arg36 Posted May 26, 2017 Share Posted May 26, 2017 I imagine you could tap into the harness for the auto-dim mirror as well. Link to comment Share on other sites More sharing options...
freaksavior Posted May 26, 2017 Share Posted May 26, 2017 I imagine you could tap into the harness for the auto-dim mirror as well. Yeah same thing. You may want to consider a low 3a inline fuse, but any constant power would work. Thanks for that idea...I h adn't considered using the dome light. Yeah man. No problem. This is how I did mine http://legacygt.com/forums/showpost.php?p=5520803&postcount=1365 Link to comment Share on other sites More sharing options...
