Slammed05 Posted May 23, 2017 Share Posted May 23, 2017 I know there are plenty of threads in this, but I cannot find one or confirm if a pedal assembly from a 2003 wrx with be a direct swap to a 2005 lgt Kinda hard to tell from the pictures, and it seems like most of the threads people are using the 11+ wrx pedals, so just trying to confirm this before I buy a 2003 assembly Link to comment Share on other sites More sharing options...
compsurge Posted May 23, 2017 Share Posted May 23, 2017 Try looking for part numbers on here. http://opposedforces.com/parts/impreza go to the correct year range, then Manipulation > Pedal Assembly. Link to comment Share on other sites More sharing options...
Slammed05 Posted May 23, 2017 Author Share Posted May 23, 2017 It says error page Link to comment Share on other sites More sharing options...
compsurge Posted May 23, 2017 Share Posted May 23, 2017 Lol autocorrect in a URL. /impreza Link to comment Share on other sites More sharing options...
DrD123 Posted May 24, 2017 Share Posted May 24, 2017 the 2005 LGT is drive by wire, while the 2003 WRX still uses a throttle cable, so no, pedal assembly is not going to work if that assembly includes the accelerator pedal. Link to comment Share on other sites More sharing options...
shiddytiddys Posted May 31, 2017 Share Posted May 31, 2017 the 2005 LGT is drive by wire, while the 2003 WRX still uses a throttle cable, so no, pedal assembly is not going to work if that assembly includes the accelerator pedal. Do you think It'd work on a 2001 LGT? Lol Link to comment Share on other sites More sharing options...
compsurge Posted June 5, 2017 Share Posted June 5, 2017 Do you think It'd work on a 2001 LGT? Lol Use the link provided and cross reference part numbers. Link to comment Share on other sites More sharing options...
