SpecBlitzed Posted May 22, 2017 Share Posted May 22, 2017 Option A : 04 Sti Brembo Option B: 08+ Sti Brembo For both options from what I found i need Front Sti Rotors and both options should be direct bolt on. Will my stock brake lines work for now until I upgrade to SS lines. As for the rear Iam still a bit confused. I've read about how the e brake shoes require a hybrid rotor that works with the factory e brake pads but works with the rear Brembo caliper. From what I read the 04 Brembo requires an adapter bracket to fit the larger rotor. Does the 08+ Brembo require the adapter or just the hybrid rotor. Then a direct bolt up. I understand the front without question just gonna buy new 04 Sti rotors and bolt on the front. Just need help with the rear conversion. I know the internet is full of info just need someone with knowledge who can clarify before I start spending money on things I don't need. Link to comment Share on other sites More sharing options...
Rhitter Posted May 22, 2017 Share Posted May 22, 2017 http://legacygt.com/forums/showthread.php/08-sti-brembos-05-lgt-262145.html My OBXT build Link to comment Share on other sites More sharing options...
PimpFro Posted May 22, 2017 Share Posted May 22, 2017 For the rears you will need 04-07 STI Brembo calipers, 04 STI rear rotors, adapter bracket for the calipers, 4 Brembo bolts pt # 901000326, and the e-brake shoe adapter which changes the ebrake size from 170mm to 190mm Or 04-07 STI Brembo calipers, 04 STI rear rotors that have been specially tooled to adapt to the 170mm e-brake show, adapter bracket for the calipers, and 4 Brembo bolts pt # 901000326 Those are the options thus far, DBA makes the specially tooled rotor KNS makes the specialized e-brake shoe There is a local working on adapting an 04 STI e-brake shoe to fit the 4th Gen legacy but that will likely be a 1 off item. I am currently exploring ways to possibly get the 08+ STI caliper to work on the 4th Gen models but it may prove to be not worthwhile. Some differences between the 04-07 and the 08+ are Piston size went up by 4 mm, offset changed for the caliper, and mount points changed. The 08+ will bolt up to the factory location after removing the dust shield but.... it won't work correctly Pure Adrenaline Attached... To A License Plate Link to comment Share on other sites More sharing options...
SpecBlitzed Posted May 22, 2017 Author Share Posted May 22, 2017 Thanks for the help. Gonna go with a set of 05 STi Brembos. I am waiting for the car to show up next week at the yard to pull the calipers. Guy is asking $750 for a full set and I couldn't be more excited to find a deal. Fingers crossed the calipers are in healthy condition. Once I acquire the calipers I'll be searching for a deal on rotors and pads. Planning on purchasing the KNS rear caliper adapter bracket and the larger Brembo swap e brake shoes. Most likely go all out and do the SS brake lines as well. Gonna be smart and shop around for the best deals for a budget Brembo swap. Any leads on deals for the swap please message me. I'll be posting pix when the swap is complete Link to comment Share on other sites More sharing options...
