SIMMON Posted May 17, 2017 Share Posted May 17, 2017 I have a question that I hope you can help me with: How do I remove the dashboard? To change bulbs and maintenance area. I could not find instructions how to do it without causing damage Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 17, 2017 Share Posted May 17, 2017 With most subarus it's starts with removing the trim piece around the shift knob. Then removing the bezel for the radio surround. Then you gain access to the screws that hold the shroud around the gauge cluster. On older subarus I'm sure it's much easier. Get a long and stubby screwdrive with a magnetic tip. If you can find some of these tools - https://www.google.com/search?q=5+piece+trim+removal+tool+set&rlz=1C1CHBF_enUS738US738&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj-j8aryPfTAhWCQCYKHTIUBBEQ_AUICygC&biw=1440&bih=794 Link to comment Share on other sites More sharing options...
