JackLGT Posted May 3, 2017 Share Posted May 3, 2017 Okay so I had to get my battery replaced as it was dead, so I did that and it worked good, but it didn't start the first time. The second time it did, but the Cobb AP (V3) would not turn on. Is this a blown fuse or what could it be? Thank you!! Link to comment Share on other sites More sharing options...
madrig Posted May 4, 2017 Share Posted May 4, 2017 didn t start the first time is normal . i dont now about your access port , never had one , when you unplug the battery you reset your ecu . Link to comment Share on other sites More sharing options...
relative4 Posted May 4, 2017 Share Posted May 4, 2017 Does it still not turn on? Did you leave it plugged in when you replaced the battery? If the answer to both these questions is yes, then check the AP owner's manual for mention of an internal fuse. Link to comment Share on other sites More sharing options...
