Adam144 Posted April 24, 2017 Share Posted April 24, 2017 On our 2010 Legacy 2.5 CVT when selecting reverse sometimes the display will show "D" or go blank instead of "R". Everything functions normally otherwise but randomly having the wrong letter appear in the readout is annoying. Is there a switch/sensor that would cause this in the gear selector or trans? Anyone else had this issue? Link to comment Share on other sites More sharing options...
FAILBOT Posted April 25, 2017 Share Posted April 25, 2017 There is a switch that connects to the TCM module, then the TCM sends the info over CAN bus to the cluster for which gear to display. You could possibly have that switch going bad, some weird issue with the TCM module or cluster, OR your transmission is actually in that gear. I'm not sure how that switch actually connects to the transmission or gear selector as I've never messed with it. Link to comment Share on other sites More sharing options...
Adam144 Posted April 25, 2017 Author Share Posted April 25, 2017 There is a switch that connects to the TCM module, then the TCM sends the info over CAN bus to the cluster for which gear to display. You could possibly have that switch going bad, some weird issue with the TCM module or cluster, OR your transmission is actually in that gear. I'm not sure how that switch actually connects to the transmission or gear selector as I've never messed with it. It doesn't do it every time, it is random. All other letters on the display work. P in park, D in drive etc. Just in reverse it's either blank where the letter should be or it displays a D. The car is still in reverse, still works properly. It just goes blank or shows a D when there should be the R on the readout. Seems strange. Is the switch external? (Accessible from inside the car or underneath?) or is it inside the trans? Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted April 25, 2017 Share Posted April 25, 2017 The prndl switch is on passenger side of car and is responsible for telling the TCM what range the transmission is in. I would investigate that first... Link to comment Share on other sites More sharing options...
FAILBOT Posted April 26, 2017 Share Posted April 26, 2017 If you don't get any letter or it stays on another, then most likely the switch is not moving the internal contacts where they need to be. No display means no contact. Link to comment Share on other sites More sharing options...
