hal9e3 Posted April 13, 2017 Share Posted April 13, 2017 I have had the JDM console with a single din aftermarket H/U in my car for about 5 years now. A little while back it started blowing only hot air thru the driver's side vents regardless of the temp setting. The passenger's side vents work fine - cold air when turned down, warm air when up. I've heard that other people have had this issue. If so what's the fix? I'd like a little more ammo before I tear my interior apart. Turning A/C on has little or no effect on driver's side air temp. Link to comment Share on other sites More sharing options...
MilesA Posted April 14, 2017 Share Posted April 14, 2017 There is always hot water flowing through the heater core. The amount of hot air that gets mixed into the cabin air system depends on the position of a door or flap in the duct on each side. Most likely, the driver's side flap is staying open all the time. Likely causes could be a wiring problem or a fault in the motor that controls that flap. Link to comment Share on other sites More sharing options...
