Andrew1707 Posted April 6, 2017 Share Posted April 6, 2017 Have any of you used these generic sway bar link kits and bushings I see on eBay? Buying a 22 mm RSB, do I need to spend another 130$ on white line or AVO links or can I get away with these? Link to comment Share on other sites More sharing options...
henhead Posted April 6, 2017 Share Posted April 6, 2017 If you need new end links to replace some old OEM ones get the Moog's off of RockAuto. They are beefier than OEM and can be re-greased. Just the rear's should cost no more than $40. I want to say I got all 4 (F&R) for about 60. Link to comment Share on other sites More sharing options...
Andrew1707 Posted April 7, 2017 Author Share Posted April 7, 2017 Thanks, 12.98$ each. Link to comment Share on other sites More sharing options...
relative4 Posted April 7, 2017 Share Posted April 7, 2017 You probably already know this, but you'll need AVO brackets for that bar. Link to comment Share on other sites More sharing options...
Andrew1707 Posted April 8, 2017 Author Share Posted April 8, 2017 The white line bars don't come with new hardware? Link to comment Share on other sites More sharing options...
Andrew1707 Posted April 8, 2017 Author Share Posted April 8, 2017 I assumed it would come with some kind of bigger brackets??? Link to comment Share on other sites More sharing options...
