HipsterJesus Posted April 6, 2017 Share Posted April 6, 2017 So I own a 2009 Subaru Legacy 2.5I Special Edition with the HK stereo system. The other day, I replaced my head unit with a Bluetooth model from pioneer. Threading being the audio was cutting in and out , so I figured since the Aux Jack was loose, it was that. After installing the new stereo, the audio was still in and out, but just the two 6.5" in the front and the tweeters and 5 14" in the rear doors. Finally, after driving for a few minutes, the audio cut out completely, leaving only the front tweeters and subwoofer working, and smell of over heating electronics. The system is 440w with a 10 ohm impedance (which is odd). I have checked all fuses, and even disconnected and reconnected the battery to check if it was in a form of protection mode. If it is the amp, what should I get for a replacement? Any help would be amazing. Link to comment Share on other sites More sharing options...
rvnmaniac Posted April 7, 2017 Share Posted April 7, 2017 Tap Tap Tap. I'm in the same boat... Except new system hasn't arrived yet. Link to comment Share on other sites More sharing options...
apexi Posted April 7, 2017 Share Posted April 7, 2017 Do you have an aftermarket amp, or stock amp? I'm reading the legacy has either a 380 or 385 watt amp, and that the outback is 440w. Link to comment Share on other sites More sharing options...
rvnmaniac Posted April 7, 2017 Share Posted April 7, 2017 I purchased the car 3 months ago 56k miles. There were two pennies jammed in the cigarette lighter. I needed a needle nose plier to pull them out, they were really jammed in there. They didn't just happen to fall in there. Two weeks later I'm having problems with the stereo. Anybody know why the pennies would be in the cigarette lighter. Was it preventing an electrical issue? Link to comment Share on other sites More sharing options...
rvnmaniac Posted April 12, 2017 Share Posted April 12, 2017 I have a feeling I should find out this problem before I purchase a new unit. Would hate to put in a new head unit and still have the speakers going in and out, snap crackle and pop. No one else with a 2009 have this problem???? Link to comment Share on other sites More sharing options...
ttnio Posted April 12, 2017 Share Posted April 12, 2017 I would remove the radio,disconnect all the wires from the back of the radio,and then set everything back carefully. Disconnect your battery first before the above. Link to comment Share on other sites More sharing options...
rvnmaniac Posted April 30, 2017 Share Posted April 30, 2017 Cured my problem with a Jensen 7020 Link to comment Share on other sites More sharing options...
