gimpydingo Posted March 30, 2017 Share Posted March 30, 2017 I'm in process of a Stg 2 tune, cleared up my exhaust leak and can hear a very faint whine. Pressured the system to check for leaks with soapy water as I have before and found 2 what I believe is the fuel injectors leaking on the drivers side. I've looked at the vacation pics, these seem to be the injectors. Can someone confirm? Depending on that answer should new o-rings fix that or new injectors recommended? Link to comment Share on other sites More sharing options...
LPStandard Posted March 30, 2017 Share Posted March 30, 2017 Pretty definitive there. I would start with o-rings, simple and quite a bit cheaper than injectors. Link to comment Share on other sites More sharing options...
gimpydingo Posted March 30, 2017 Author Share Posted March 30, 2017 Another new project for me. I've never pulled the injectors before. Any DIY's? I only find the one showing a side feed being pulled from the passenger side. Link to comment Share on other sites More sharing options...
Andy_Mac Posted March 30, 2017 Share Posted March 30, 2017 Had mine leak in the same spot after doing the TGV delete, luckily reseating the injector fixed it but doubt you'd be that lucky if you haven't had the injectors out before. Not the most relevant one but thats what I used when doing the Airpump and TGV delete which I had to remove the injectors for. http://legacygt.com/forums/showthread.php/2007-2009-air-pump-delete-cel-codes-and-ecu-fix-140259.html 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
gimpydingo Posted March 31, 2017 Author Share Posted March 31, 2017 Thanks. Happened to find this as well. https://forums.nasioc.com/forums/showthread.php?t=2308068 Link to comment Share on other sites More sharing options...
