Firepuma Posted March 22, 2017 Share Posted March 22, 2017 Seems like mine has taking its last crank- thankfully it's in the closed position. Any advise or info on where in the headliner the motor is located and how much of a pita is it to change out? Link to comment Share on other sites More sharing options...
madrig Posted March 22, 2017 Share Posted March 22, 2017 the motor is in the back . you can locate it , close to the trunk light , you will find the safety cap , remove this cap and you can crank manually the motor . you will have no choice to remove the headliner to do any work . Link to comment Share on other sites More sharing options...
