Kharl Posted March 9, 2017 Share Posted March 9, 2017 Hi guys after 4 years of random battery discharges, two new batteries (one exploded), yesterday, the battery and brake lights came on, and today the vehicle shut off while running. everything points to the alternator but... i had an used alternator in my house and i did the install, and jump start the car and 10 minutes later int went off again, TWO ALTERNATORS? what other thing could cause the battery not charging? Link to comment Share on other sites More sharing options...
RumbleRumble Posted March 9, 2017 Share Posted March 9, 2017 What's the Year and Model of your car? Mod should move this. Link to comment Share on other sites More sharing options...
Kharl Posted March 9, 2017 Author Share Posted March 9, 2017 What's the Year and Model of your car? Mod should move this. Sorry i did not specify Legacy 93 Link to comment Share on other sites More sharing options...
GTEASER Posted March 9, 2017 Share Posted March 9, 2017 did you check the voltage to the battery with a dmm while it was running? sounds like you have some inherent problem with the wiring or a relay sticking. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Kharl Posted March 9, 2017 Author Share Posted March 9, 2017 the voltage with the battery is dying while running, completely not receiving charge from the alt.. a year ago the votage raised to 14.2, wht it should be but with ll accesories on it started to low, i mean the alternator coudlnt deal with all the load, cold that be a early sympton of a faulti alternator, but two bad alternators? Link to comment Share on other sites More sharing options...
TylerHartman Posted March 12, 2017 Share Posted March 12, 2017 Sounds like a Slipping Belt, Alternator, Bad Ground or signs of failing battery. I'm leaning towards alternator. Link to comment Share on other sites More sharing options...
Kharl Posted March 13, 2017 Author Share Posted March 13, 2017 HI guys! thank you a lot for the time you spend helping me with this i decide to do a rebuild, all electronic was bad, they put a new diode card and an used regulator, and gave me warranty, everything working fine by now Thank you! Link to comment Share on other sites More sharing options...
