markomilanovic Posted February 18, 2017 Share Posted February 18, 2017 I was looking at replacing my factory dash in my subaru with a nexus 7 tablet. Currently the reverse camera is connected to the factory unit with the factory connector. I was wonder if it would be possible to adapt the camera so I would be displayed on the nexus 7 tablet. I've been told it needs to be adapted to usb but I can't find such an adapter. Any help would be greatly appreciated! Link to comment Share on other sites More sharing options...
TurtleWaffle Posted February 19, 2017 Share Posted February 19, 2017 Just finished up my nexus 7 install with the JDM bezel. I don't have a backup cam but have been researching it quite a bit. To start with, you're going to want to use Timur's Kernel. It has support for backup cams with the use of a compatible usb converter. Timur's site recommends UVC compatible devices. You can find more info here: https://timur.mobi/timurs-kernel-n7-2013/ Link to comment Share on other sites More sharing options...
markomilanovic Posted February 19, 2017 Author Share Posted February 19, 2017 I've set up the tablet with that kernel etc. Just need to find a USB adapter for the stock Subaru reverse camera as I really don't want to lose that functionality. It would render the whole upgrade useless. Could you point me in the direction of such a converter? Thanks very much for you reply and help Link to comment Share on other sites More sharing options...
TurtleWaffle Posted February 20, 2017 Share Posted February 20, 2017 What kind of connector is on the stock backup cam? I'm not familiar with it and can't find much info online. If it's just a simple RCA connection then you can buy something like this: https://www.amazon.com/VOLD-Capture-Device-Remote-Network/dp/B01N0V9285/ref=sr_1_1?ie=UTF8&qid=1487555182&sr=8-1&keywords=usb+rca+converter+uvc If it has it's own harness, then you should be able to adapt it to RCA and power input. You would then connect the power to your reverse lights or to a relay for manual control. Then add a converter like the one above and you should be good. Link to comment Share on other sites More sharing options...
