landcrush Posted February 3, 2017 Share Posted February 3, 2017 Not sure if this should be in turbo specific forum but Looking to source stock size AB pistons for my 08 specB rebuild Quick google search reveals DNJ or NPR pistons which appear to be cheap Tawainese or Chinese pistons. These companies offer a 'complete rebuild kit' which includes everything (Still going with OEM Gasket kit) The whole kit is something like $600 Heuberger has OEM for 75-95 a pop. Plus rings they'd be around $500 Only forged option I'm considering would be Wossners or Mahles or similar 4032 offerings. With rings these would probably be around $750 I know I know I should've just bought an EJ257 shortblock. I've already gotten this deep into my motor and I'm fairly confident I can do it for less than the $1900 for the SB, plus assembly. Link to comment Share on other sites More sharing options...
Rhody Posted February 3, 2017 Share Posted February 3, 2017 http://crawfordperformance.com/products/take-out-pistons-sti-ej257 This appears to be your best option for pistons if going OEM. They include wrist pins. $25/piston. Just need to source rings. Check out StkmltS and MaxCapacity's info on engine rebuilds. Good luck! Link to comment Share on other sites More sharing options...
landcrush Posted February 3, 2017 Author Share Posted February 3, 2017 Perfect just what I was looking for thank you! I've read MaxCaps will check out Stkmlts as well I know Max just went with the new SB Link to comment Share on other sites More sharing options...
