vwgetta18 Posted January 30, 2017 Share Posted January 30, 2017 Been having problems with my stock head unit on my legacy 2.5i 2008 every time I put a disc in it keeps saying eject disc Tried ejecting disc same thing even tried another disc same exact thing checked fuses everything is okay radio works just not the CD player Even tried going out a buying a disc cleaner doesn't seem to help at all Please someone help me Sent from my SM-G935V using Tapatalk Link to comment Share on other sites More sharing options...
Stumpel Posted January 30, 2017 Share Posted January 30, 2017 Check ebay for a replacement head unit. I found one for my 06 for $35.00. Link to comment Share on other sites More sharing options...
vwgetta18 Posted January 31, 2017 Author Share Posted January 31, 2017 Oh really so basically my head unit took a crap the laser I guess won't read the discs anymore Sent from my SM-G935V using Tapatalk Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted January 31, 2017 I Donated Too Share Posted January 31, 2017 Unless it's something mechanical which you can fix and you're inclined to take it apart, your best bet is to try and find a replacement as suggested. If you're asking on here to find out if there's a magic button sequence to make it work again, unfortunately there isn't. Last ditch attempt you can try is some percussive maintenance but really that needs to be applied from the top down so you still need to remove it from the dash for application. Link to comment Share on other sites More sharing options...
vwgetta18 Posted January 31, 2017 Author Share Posted January 31, 2017 Alright I will check out eBay then thanks guys Sent from my SM-G935V using Tapatalk Link to comment Share on other sites More sharing options...
