Jdubgt530 Posted January 25, 2017 Share Posted January 25, 2017 I recently install my speedyracer Uel headers and noticed that from the passenger head the header was really close to the oil pan. I hit my buddy up about it and he said he got an sti oil pan and pick up but can't remember what year exactly worked for him. I was wondering if anyone knew which year I should look for my ej25d. Link to comment Share on other sites More sharing options...
wtdash Posted January 26, 2017 Share Posted January 26, 2017 Not the answer you're looking for, but due to the PITA to swap, could you just put some Heat Wrap on the header? Should be less work and probably cheaper. Link to comment Share on other sites More sharing options...
Jdubgt530 Posted January 27, 2017 Author Share Posted January 27, 2017 When I installed them I wrapped the headers in titanium wrap. It's literally almost touching the oil pan so I would just feel more comfortable to replace the oil pan to fix the problem. Thanks for the advice though! Link to comment Share on other sites More sharing options...
Jdubgt530 Posted January 27, 2017 Author Share Posted January 27, 2017 I was planning on doing it when I pull the engine for the rear main, oil separator, and clutch. Have a bad leak going on that's all over the transmission and cros member Link to comment Share on other sites More sharing options...
Rhody Posted January 27, 2017 Share Posted January 27, 2017 This might be helpful. https://forums.nasioc.com/forums/showthread.php?t=1756427&page=2 I believe your oil pan is part number 11109AA053 which is the same as the OEM 2002-2005 EJ20 WRX Oil Pan. I do not know if putting an STI oil pan on your car would fit with your headers however. Good luck! Link to comment Share on other sites More sharing options...
Senseless1 Posted February 2, 2017 Share Posted February 2, 2017 I've read about people using this pan as an upgrade for the older EJ motors, but not sure how fitments would be for your setup. Are your headers the NA headers or turbo headers? Link to comment Share on other sites More sharing options...
Jdubgt530 Posted February 9, 2017 Author Share Posted February 9, 2017 NA Uel headers from speedyracer. Link to comment Share on other sites More sharing options...
killerbmotorsport Posted June 14, 2017 Share Posted June 14, 2017 Just to follow up, any pan can be used on any EJ engine since the blocks are all the same from the bottom. You just need to be sure the corresponding pickup and baffle is used. Switching to the 06+ Sti pan is a good intermediate upgrade providing some insurance from oil starvation in the corners. The other nice thing about going with this pan is that it will fit ANY headers out there. Even ours Link to comment Share on other sites More sharing options...
