acdcrockme Posted January 24, 2017 Share Posted January 24, 2017 Im sure its been posted before but i just bought a 99 b4 rsk sedan 5mt and i need to do my belts and rear diff carrier bushings what are the part numbers or what parts off a usdm car will work i need timing belt powersteering/alternator belt and ac belt. I also need to know what bushing to get or what bushings work for the rear diff carrier? Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 24, 2017 Share Posted January 24, 2017 I think a 2002 wrx engine is the same 2.0 as the JDM minus one turbo. Link to comment Share on other sites More sharing options...
acdcrockme Posted January 25, 2017 Author Share Posted January 25, 2017 I think a 2002 wrx engine is the same 2.0 as the JDM minus one turbo. I tried a wrx alternator belt and before i took off the old one i could tell the belt was too small. I also know the engines have some differences in the internals. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 25, 2017 Share Posted January 25, 2017 Can you get a part number off the old belt Link to comment Share on other sites More sharing options...
acdcrockme Posted January 26, 2017 Author Share Posted January 26, 2017 Can you get a part number off the old belt I managed to but turns out its not even the belt i was hearing it was my wheel bearing Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 27, 2017 Share Posted January 27, 2017 Oh that stinks Link to comment Share on other sites More sharing options...
RustyRuu Posted January 27, 2017 Share Posted January 27, 2017 from an 05 but essentially the same. http://legacygt.com/forums/showthread.php/front-wheel-bearing-diy-walkthrough-86994.html Link to comment Share on other sites More sharing options...
RustyRuu Posted January 27, 2017 Share Posted January 27, 2017 and rear http://legacygt.com/forums/showthread.php/diy-rear-wheel-bearing-replacement-walk-through-w-pdf-188666.html Link to comment Share on other sites More sharing options...
Sara32013 Posted January 28, 2017 Share Posted January 28, 2017 I would think a Subaru dealership would be able to get everything you need, for the belt you can just take them to a parts store, they can usually measure them and get the right ones for you. Link to comment Share on other sites More sharing options...
thedocta Posted March 7, 2017 Share Posted March 7, 2017 Hey. If you still need it http://opposedforces.com/parts/ That shows all the usdm equivalent for most jdm parts. I used to to get the bushings for my rear diff housing too. Among other things too. Link to comment Share on other sites More sharing options...
