Lego3410 Posted January 21, 2017 Share Posted January 21, 2017 So I've got an 05legacy gt that I'm changing the valve cover gaskets on.. I'm working on the passenger side and I've got air box out two hoses that connect to valve cover off all 8 bolts off the cable cover and now I can't see to get the blasted thing out.. seems to keep catching on something. And I do have the plugs out too. Do I need to lift the motor and if I do how high can I and where is a good spot to put the jack. Or are there other options? Link to comment Share on other sites More sharing options...
Gex Posted January 21, 2017 Share Posted January 21, 2017 You can totally prop up the motor to give you some clearance. I put a 2x4 on the jack and use the head to lift it 2-3" for clearance. Just undo the 14mm bolt on the motor mount. Hoses can take it. The thing is held on by the rtv. Use a little pry tool. Link to comment Share on other sites More sharing options...
Lego3410 Posted January 22, 2017 Author Share Posted January 22, 2017 Ok well I decide to try one last thing before I did that. And it worked! Just had to turn the valve cover 90degrees and pull up! Thanks gex if I have to lift the motor for anything I'll know now. Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted January 22, 2017 I Donated Too Share Posted January 22, 2017 It's a lot easier when even doing something like changing the spark plugs with Gex's suggestion. I do it every time. The two 14mm nuts on the engine mounts take moments to remove and then jack up each side of the engine in turn, really easy and quick. Link to comment Share on other sites More sharing options...
Lego3410 Posted January 22, 2017 Author Share Posted January 22, 2017 I agree should've done that to begin with! Thanks again for the help! Link to comment Share on other sites More sharing options...
MilesA Posted January 22, 2017 Share Posted January 22, 2017 You only need to jack one side at a time, so I found it useful to remove the mount bolt only on the side being raised, and just loosen the other mount bolt so it remains engaged on the last few threads. That way, the engine will stay located on the mount, and easily settles back into position when you lower it again. Link to comment Share on other sites More sharing options...
relative4 Posted January 22, 2017 Share Posted January 22, 2017 I like to leave both nuts on so the mount studs/bolts don't clear the bracket allowing the spacer plates to fall off. I also disconnect the pitch stopper to maximize vertical movement while minimizing tension. Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted January 22, 2017 I Donated Too Share Posted January 22, 2017 Never ever had a problem with the engine not locating back when done. Would concern me more to leave the nuts on one side when jacking up the other side. Fine to leave both on I guess to limit movement but I don't have spacer plates or ever seen any on other cars so not sure what those are for. Things to think about anyway and now the next time I do this you know the damn engine won't go down properly for me and I will be cursing for the hours it takes me to wrestle it back into position. Thanks for that. Link to comment Share on other sites More sharing options...
