Alexander- Posted January 19, 2017 Share Posted January 19, 2017 Hello fellow Legacy owners, My car was giving me a check engine light for a P0031 and a P0037 code. I finally decided to change both sensors (air/fuel sensor and the oxygen sensor). However after clearing the codes and starting the car back up, the CEL turns back on with the same codes... Does anyone have an idea why this would happen? Alexander Link to comment Share on other sites More sharing options...
MilesA Posted January 19, 2017 Share Posted January 19, 2017 How did you clear the codes? The Check Engine Light will reset itself after three normal driving cycles (IOW the condition was not detected during a full driving cycle three times). If the CEL does not reset, you might want to test your wiring. You might suspect a broken wire or short circuit. Maybe a wire melted and is touching ground. If you have a multimeter, you can see if you are getting battery voltage on the O2 sensor heater circuit a few seconds after the car has started. Hope that helps. Link to comment Share on other sites More sharing options...
Alexander- Posted January 19, 2017 Author Share Posted January 19, 2017 How did you clear the codes? The Check Engine Light will reset itself after three normal driving cycles (IOW the condition was not detected during a full driving cycle three times). If the CEL does not reset, you might want to test your wiring. You might suspect a broken wire or short circuit. Maybe a wire melted and is touching ground. If you have a multimeter, you can see if you are getting battery voltage on the O2 sensor heater circuit a few seconds after the car has started. Hope that helps. I cleared them using an eBay OBD2 scanner. I guess I will try to use the car for a couple days and see if the CEL resets. If not, I guess I will have to start checking wires. Btw, do you have any reference to your statement of 3 normal driving cycles for a CEL reset? Thanks for your input Link to comment Share on other sites More sharing options...
MilesA Posted January 19, 2017 Share Posted January 19, 2017 ...do you have any reference to your statement of 3 normal driving cycles for a CEL reset? Factory Service Manual, DTC Detection Criteria Search for "vacation pix" if you don't have them, they will help. Link to comment Share on other sites More sharing options...
Alexander- Posted January 19, 2017 Author Share Posted January 19, 2017 Factory Service Manual, DTC Detection Criteria Search for "vacation pix" if you don't have them, they will help. Thanks for the manual! Link to comment Share on other sites More sharing options...
