agctr Posted July 30, 2004 Share Posted July 30, 2004 For the MY01, the AT model had two buttons, a POWER button and a HOLD button. The POWER button obviously remapped the ECU to give the car more power when required. (have to admit, I have never used it). The 2nd button, the HOLD button is actually for the snow or slippery surfaces. When switched on, a little snow flake appears on the dash indicating you are in this mode. The car's ECU is then told to take off out of 2nd gear and not first to reduce wheel spin on take off. It also very handy when you are on a slight hill or incline as with most AT cars the car will roll forward as still in gear. With this function is turned on, it wont roll anywhere which is a great feature. Unsure why they havent put these feature into the new GT. Subaru Oz were unable to answer this either? Link to comment Share on other sites More sharing options...
Information Society Posted August 21, 2004 Share Posted August 21, 2004 If you want power mode, leave the shifter in the sportshift area and don't shift it. The POWER light should come on on your dashboard. I think also that the sportshift eliminates the need for a HOLD feature. [quote name='agctr']For the MY01, the AT model had two buttons, a POWER button and a HOLD button. The POWER button obviously remapped the ECU to give the car more power when required. (have to admit, I have never used it). The 2nd button, the HOLD button is actually for the snow or slippery surfaces. When switched on, a little snow flake appears on the dash indicating you are in this mode. The car's ECU is then told to take off out of 2nd gear and not first to reduce wheel spin on take off. It also very handy when you are on a slight hill or incline as with most AT cars the car will roll forward as still in gear. With this function is turned on, it wont roll anywhere which is a great feature. Unsure why they havent put these feature into the new GT. Subaru Oz were unable to answer this either?[/quote] Link to comment Share on other sites More sharing options...
agctr Posted August 23, 2004 Author Share Posted August 23, 2004 I will have to check that out Thanks. The hill hold in my mind was a good idea and especially in the snow too but I think u can start the car in 2nd. Adam Link to comment Share on other sites More sharing options...
