SBT Posted January 14, 2017 Share Posted January 14, 2017 Two things. 1) Use a torque wrench to tighten to spec - impact guns are typically over/under spec. 2) Never put the weight of the car on the wheel that axle until the axle nut is torqued to spec. Otherwise you risk damaging the bearings and you get to wash, rinse and repeat it all again. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
