2000GTWagon Posted January 3, 2017 Share Posted January 3, 2017 For my 2009 Outback I'm thinking of coilover shock/spring replacements because, I assume, I can DIY at home without the use of a spring compressor, and I gain adjustability. I would love to reign in that bouncy too-soft back end. But I am not looking for a rally/race car How problematic are these systems like BC Racing Coilovers (BR Type, made for Outback's street ride height) - in everyday street use, for years of use? Are these durable designs? Do alignment shops willingly service them; and what about tire wear? Thanks! ...OR, Plan B: "Complete Strut Assemblies" (non-adjustable) that are just cheap OEM-like replacements, easy to install without a spring compressor. I don't know if the 2004 Outback's complete rear spring/shock assembly will appropriately replace my 2009 as reportedly the shock only does. And if so, will it improve the ride and handling? That would be cool. I called one company and they told me that they refused to sell a mixed set. (cross-posted from another forum, sorry if you saw this before) Link to comment Share on other sites More sharing options...
Rhitter Posted January 3, 2017 Share Posted January 3, 2017 Spring compressors are 30 bucks....https://www.amazon.com/OEMTOOLS-25550-MacPherson-Spring-Compressor/dp/B000CMDPLM/ref=sr_1_4?ie=UTF8&qid=1483467054&sr=8-4&keywords=spring+compressor+tool I have been using those for years with no issues. Sure it's a little slow. But they are not hard to use. A coilover is not as durable as a strut/spring. Usually they require rebuilds every 30k miles. You should not have an issues with an alignment shop if you have coilovers. If you do, go to a different alignment shop. Tire wear is 100% dependent on your alignment. I assume the other forum was Subaruoutback.org? They have a great FAQ on improving the Outbacks suspension. What is it about adjust-ability that appeals to you? What are you going to adjust? My OBXT build Link to comment Share on other sites More sharing options...
