seiyafan Posted December 17, 2016 Share Posted December 17, 2016 So I took my car to a local shop for oil change, after new oil was added the engine was left running for a while then the mechanic showed me the dipstick, the level was half way between the min. and max. marking. After I drove home that night and checked the oil level again myself, the level had gone up above the max. marking (I'd say it's about half a quart over), is this how it suppose to behave? Link to comment Share on other sites More sharing options...
cww516 Posted December 17, 2016 Share Posted December 17, 2016 Yeah, that's pretty normal. Check again after it's been sitting for half an hour or so, it should be a little more in line with what you'd expect to see. Link to comment Share on other sites More sharing options...
ehsnils Posted December 17, 2016 Share Posted December 17, 2016 Level shall always be checked when engine isn't running and has been stopped for a few minutes. Too much oil is also bad since it can come back into the intake through the crankcase ventilation or cause seals to pop out. Link to comment Share on other sites More sharing options...
