Trevorm34 Posted December 4, 2016 Share Posted December 4, 2016 Hi, I have a 2000 Legacy GT Limited. Both of the radiator fan motors died so my car will overheat if i am idle or in traffic after a bit, but will cool down when going at a decent speed. I have tried getting with subaru dealerships but am having no luck and I can't find anything online that i am sure that will work. Basically i need help finding either the motors or just the whole fan assembly. Thanks. Link to comment Share on other sites More sharing options...
RumbleRumble Posted December 4, 2016 Share Posted December 4, 2016 Free things first. Check fuse,relay,wiring. If you think you need a new assembly try a junkyard Link to comment Share on other sites More sharing options...
Trevorm34 Posted December 4, 2016 Author Share Posted December 4, 2016 Free things first. Check fuse,relay,wiring. If you think you need a new assembly try a junkyard I did. Plus the motors don't run when they are hooked up to the battery or an external power source. Link to comment Share on other sites More sharing options...
RumbleRumble Posted December 4, 2016 Share Posted December 4, 2016 620-820 is dorman fan assembly one side only about 55$ Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 8, 2016 Share Posted December 8, 2016 engine fan https://www.carid.com/2000-subaru-legacy-engine-cooling-parts/tyc-fans-43162501.html A/C fan http://www.autopartswarehouse.com/shop_parts/a-fs-c_condenser_fan/subaru/legacy.html do the motors spin freely? Link to comment Share on other sites More sharing options...
