dgrinnell Posted December 2, 2016 Share Posted December 2, 2016 Alright guys I'm just picked up a 93 legacy wagon awd for cheap for my new dd. It's running rough and seems to not have the power it supposed to have. Ithe run rough at ideal and while running up in rpms. I've already put new plugs and wires and nothing changed. I also pulled the codes which we 14 16 and 17 which says fuel injectors. I can pull the passenger front injector wire off and have no change but when I pulled the others it will die. I'm at a lost here as I don't know much about subarus. I've also changed the fuel filter. I'm sure someone else has had this issue before so I'm looking for some help. Link to comment Share on other sites More sharing options...
me and my metro Posted December 4, 2016 Share Posted December 4, 2016 I have replaced several injectors since they made us use e10 fuel. Hit the local wrecking yard and get sets of four out of wrecked Subes. Link to comment Share on other sites More sharing options...
wtdash Posted December 6, 2016 Share Posted December 6, 2016 Get a multimeter and test the resistance on the injector(s). Read this: http://legacygt.com/forums/showthread.php/fuel-injector-resistance-tolerancei-197719.html Do some Googling but I think you need the '92+ red injectors for your '93. Link to comment Share on other sites More sharing options...
