McLegacy Posted November 14, 2016 Share Posted November 14, 2016 I just bought 17x7.5in wheels with tires that push the diameter to 26.5in. Originally I was thinking KYB GR-2s with forester springs. Now I have read so many posts about outback suspension and spacers and trailing arms and king springs and fender rolling that I have no idea what I'm doing anymore and I need some direction. Has anyone done this, what did they do, what do I buy, do I need spacers or trailing arms?? Thanks. I need to be able to have this all figured out Link to comment Share on other sites More sharing options...
Setnev Posted November 14, 2016 Share Posted November 14, 2016 You will basically buy everything that an Outback has on it stock. Below is the parts listed to get another inch or so out of your Legacy. OEM Body-lift parts: 20570AC040 (2x) - Front Subframe Spacer 95-99 OBK 20540AC000 (2x) - Front Subframe bolts 95-99 OBK 34160AC030 - Steering Joint (longer) 95-99 OBK 20570AC030 (2x) - Rear Subframe Spacer 95-99 OBK 901000167 (4x) - Rear Subframe bolts 95-99 OBK 41337AC010 (2x) - Rear Diff support spacer 95-99 OBK 41321AC020 (2x) - Rear Diff mounting brackets 95-99 OBK 41332AC000 (2x) - Rear Diff mounting bolt 95-99 OBK 20520AC030 - RH Trailing link bracket 97-99 OBK 20520AC040 - LH Trailing link bracket 97-99 OBK 41021AC370/41021AC330/41021AC470 - 5MT Transmission crossmember 95-99 OBK 41040AC000 - Pitch rod 95-99 OBK 32035aa060 - Pitch rod mount (transmission side) 03+ Forester/95-99 OBK Throw on some stock Outback struts and springs and you're good. The other thing you can do after that is strut spacers. There are manufacturers that make anywhere from 1" to 5" spacers for the BD/BG/BK. Link to comment Share on other sites More sharing options...
McLegacy Posted November 15, 2016 Author Share Posted November 15, 2016 Wow! Thank you! Link to comment Share on other sites More sharing options...
