Jiyujin Posted December 3, 2016 Author Share Posted December 3, 2016 Would like to see your setup, am guessing the you have the VVT engine? Link to comment Share on other sites More sharing options...
bomberlegacy Posted December 3, 2016 Share Posted December 3, 2016 I'll PM you to not clutter up your thread '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
Jiyujin Posted December 4, 2016 Author Share Posted December 4, 2016 It seems that the ignition coil was the source of the flat spot / hesitation when accelerating. After replacing it, the problem seems to have gone. Loaded an updated tune and will take it for a test drive tomorrow...fingers crossed all will be sorted. Link to comment Share on other sites More sharing options...
Jiyujin Posted December 14, 2016 Author Share Posted December 14, 2016 Installed another set of tested injectors (same flow rate) to check if they were the cause of the idle bounce, no change. Link to comment Share on other sites More sharing options...
bomberlegacy Posted December 15, 2016 Share Posted December 15, 2016 I may have missed it, but have you tried trading your MAF out for a known good one? Also, have you changed your pcv valve recently? '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
Jiyujin Posted December 16, 2016 Author Share Posted December 16, 2016 I may have missed it, but have you tried trading your MAF out for a known good one? Also, have you changed your pcv valve recently? Yes, on my 3rd MAF, it's new OEM. I have also replaced the pcv...forgot to mention it initially. It was 34 degrees here today and she ran badly, idling was up and down and even the hesitation when accelerating came back. Link to comment Share on other sites More sharing options...
RustyRuu Posted December 18, 2016 Share Posted December 18, 2016 its a fairly cheap part and i believe could help you if you look up other issues associated with it, you will see they are sort of similar. neutral sensor safety switch, look into that ill see if i can find the main thread. Link to comment Share on other sites More sharing options...
Jiyujin Posted December 18, 2016 Author Share Posted December 18, 2016 Cheers Rusty, will check it out! its a fairly cheap part and i believe could help you if you look up other issues associated with it, you will see they are sort of similar. neutral sensor safety switch, look into that ill see if i can find the main thread. Link to comment Share on other sites More sharing options...
Jiyujin Posted December 20, 2016 Author Share Posted December 20, 2016 Cheers Rusty, will check it out! Hey Rusty, I'm not getting any error codes or symptoms that are associated with a faulty neutral sensor safety switch. These are some of the symptoms that one would have which I found online. I have none of these issues. 1. Engine will not crank in park but cranks in neutral 2. Engine will not crank in neutral but cranks in park 3. Engine does not crank at all, regardless of the transmission gear 4. Engine cranks in any gear Thanks anyway, do appreciate it! Link to comment Share on other sites More sharing options...
RustyRuu Posted December 21, 2016 Share Posted December 21, 2016 here are the problems I was talking about http://legacygt.com/forums/showthread.php/jerky-5-speed-manual-189786.html these people had no codes most of the time just sort of jerky throttle response when driving. and im sorry it is a long one. somewhere around posts 110 it starts to get good unless you have a automatic then never-mind to all of this. but i thought i saw a clutch master cylinder in your pictures. Link to comment Share on other sites More sharing options...
Jiyujin Posted December 21, 2016 Author Share Posted December 21, 2016 I do have an auto (4EAT), apologies should have stated it in my first post. Will read that thread to get a better idea anyway. Cheers mate! here are the problems I was talking about http://legacygt.com/forums/showthread.php/jerky-5-speed-manual-189786.html these people had no codes most of the time just sort of jerky throttle response when driving. and im sorry it is a long one. somewhere around posts 110 it starts to get good unless you have a automatic then never-mind to all of this. but i thought i saw a clutch master cylinder in your pictures. Link to comment Share on other sites More sharing options...
Jiyujin Posted January 10, 2017 Author Share Posted January 10, 2017 It doesn't look like it was the ignition coil. Idling and hesitation issues are still there....bugger! Link to comment Share on other sites More sharing options...
