SSpeed Posted October 22, 2016 Share Posted October 22, 2016 I've perused the various tach signal threads. I'm trying to install a Raptor shift light and having a heck of a time. All the threads seem to point to a pink wire. The service manual seems to show the tach signal is the 3rd wire in (A20), which is light blue with a silver stripe. http://i85.photobucket.com/albums/k62/dil222/meter1.png http://i85.photobucket.com/albums/k62/dil222/meter2.png The Raptor instructions seem to indicate I should use the 1/2 PPR setting for coil on plug, but that doesn't seem to work. Neither does the 4 cylinder setting. http://i85.photobucket.com/albums/k62/dil222/meter3.png It's the exact same light as this one on NASIOC, the LGT dash connectors are a bit different though. http://forums.nasioc.com/forums/showthread.php?t=1145195 Link to comment Share on other sites More sharing options...
SSpeed Posted October 23, 2016 Author Share Posted October 23, 2016 Just for reference, A20 (tach signal) is the red wire with silver marks on the larger connector on the back of the gauge cluster. The Raptor shift light uses the 4 cylinder setting rather than the coil on plug setting, for some reason. Link to comment Share on other sites More sharing options...
