starionesir Posted October 17, 2016 Share Posted October 17, 2016 My Blouch dom 3 has recently started to leak oil. Appears to be leaking oil where the exhaust housing and center section meet. I've talked with blouch and they say its a subaru and my engine has to have a cracked piston. My tuner says they think its a oil seal that has failed even know blouch says there is no oil seal. I have done a compression check and no issues on any cylinders. My car also does not use ANY oil at all which I would expect it to use oil with a cracked piston. Here is a picture of the burnt oil on the lower portion of the exhaust housing. Link to comment Share on other sites More sharing options...
starionesir Posted October 17, 2016 Author Share Posted October 17, 2016 I have spoken with Blouch again this morning and they recommend changing out the stock pcv system with a upgraded system like something from crawford or iag. They think that may help eliminate the oil seeping. Any other opinions or ideas? Link to comment Share on other sites More sharing options...
