Crom Posted July 29, 2004 Share Posted July 29, 2004 Hey guys, I'm getting a grinding/scraping sound from my rear end when making turns. It seems to be louder when turning right, but it's there for both directions. I inspected the rear diff. for leaks, but could not see any. Any ideas? Is that what a failing wheel bearing would sound like? I've not a clue... Pete 97 Legacy GT, AT, 69k miles Link to comment Share on other sites More sharing options...
brady_bunch Posted July 29, 2004 Share Posted July 29, 2004 Just to be on the safe side, I would definitely see a proctologist about your rear end making grinding/scraping sound. :lol: Seriously, I would have the diff inspected as well as the wheel bearings. Is it dead center or can you tell if it is coming a bit from the left or right side? That would definitely be an indicator. Link to comment Share on other sites More sharing options...
evolutionmovement Posted July 30, 2004 Share Posted July 30, 2004 You might want to check to see if the backing plate to the disc brakes is rubbing the rotor, too. Sounds stupid, but I've seen that problem several times now, though no one seems to think of it and suspects the worst. Steve Link to comment Share on other sites More sharing options...
simba Posted August 9, 2004 Share Posted August 9, 2004 I have a 1998 Legacy wagon auto. I had a problem with noise coming from the rear when making tight turns. I took it in and they "cleaned" the cluthes in the rear differantial and put new oil in and it was OK. Try talking the fuse out under the hood which will put it in 2 wheel drive and see if the problems goes away. if it does then it is the rear differantail Good luck Simba Link to comment Share on other sites More sharing options...
agctr Posted August 9, 2004 Share Posted August 9, 2004 Hmm unsure but it could be several things, the gears between 2 wheel and AWD as suggested by Simba or it could even be something as single as the squellers on the back brakes. I would get it checked out ASAP to avoid any further damage in the future. Link to comment Share on other sites More sharing options...
