abaig97 Posted October 4, 2016 Share Posted October 4, 2016 Finally did my nexus 7 in dash project, pretty simple, didnt really follow any guide just altered as I went along got a used bezel cut out the clock housing epoxyd little pieces of plastic to build up the gaps lots of bondo and sanding the nexus interfered with the ac vents so I chose to cut up one of the vents and modify it to fit, it required a lot of trimming but it still functions just a bit stiff paint epoxyd L brackets to hold the tablet in place bent the charger and aux port back 90 degreed for easier connection using timurs rom and automate launcher I got rid of the ash tray and made a wireless charging deck there, and a dual usb car charger tucked under the shifter trim to power the tablet and the wireless charger looks pretty clean, works beautifullyhttp://uploads.tapatalk-cdn.com/20161004/4dd23831dea353d15211813a43cf6a10.jpghttp://uploads.tapatalk-cdn.com/20161004/4e9c259b888ab276bbe26bc755928133.jpghttp://uploads.tapatalk-cdn.com/20161004/71df3f99be33d774177fac139b19b5a7.jpghttp://uploads.tapatalk-cdn.com/20161004/43223013a00079ab35190d00092fa986.jpghttp://uploads.tapatalk-cdn.com/20161004/df1cd330e55da0c01f29f6f14cb56fcb.jpghttp://uploads.tapatalk-cdn.com/20161004/48d23bbc98f8785353d593bacfa35103.jpghttp://uploads.tapatalk-cdn.com/20161004/0573a3ce2751b8242b660577f5054101.jpghttp://uploads.tapatalk-cdn.com/20161004/361ff3dc4f11d9182275a8ab1a72ffa7.jpghttp://uploads.tapatalk-cdn.com/20161004/88480c4b218fa9e9028e2f36ffe1e058.jpghttp://uploads.tapatalk-cdn.com/20161004/7e47ef843a93ef3d70675e118bd5173e.jpghttp://uploads.tapatalk-cdn.com Sent from my STV100-1 using Tapatalk Link to comment Share on other sites More sharing options...
abaig97 Posted October 4, 2016 Author Share Posted October 4, 2016 http://uploads.tapatalk-cdn.com/20161004/e8c5ae32ec45b64ef67998e9c27dec06.jpg Sent from my STV100-1 using Tapatalk Link to comment Share on other sites More sharing options...
battelready Posted October 5, 2016 Share Posted October 5, 2016 Nice job. You should rebondo and sand till its smooth and then plasti dip it black and itll look very close to the original color. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
abaig97 Posted October 6, 2016 Author Share Posted October 6, 2016 thats the plan for this weekend, I just got impatient, also I need to apply a matte screen protector to reduce finger prints Sent from my STV100-1 using Tapatalk Link to comment Share on other sites More sharing options...
BoyceWare Posted October 7, 2016 Share Posted October 7, 2016 Here's a link to the screen protector I use on mine. It goes on fairly easily and has been holding up well. Nexus 7 FHD Screen Protector, Tech Armor Anti-Glare/Anti-Fingerprint Google Nexus 7 FHD (2013) Screen Protectors [3-Pack] https://www.amazon.com/dp/B00E9QK2MW/ref=cm_sw_r_sms_apa_IsV9xbJNERXDV Link to comment Share on other sites More sharing options...
ZedX Posted October 24, 2016 Share Posted October 24, 2016 Finally did my nexus 7 in dash project, pretty simple, didnt really follow any guide just altered as I went along got a used bezel cut out the clock housing epoxyd little pieces of plastic to build up the gaps lots of bondo and sanding the nexus interfered with the ac vents so I chose to cut up one of the vents and modify it to fit, it required a lot of trimming but it still functions just a bit stiff paint epoxyd L brackets to hold the tablet in place bent the charger and aux port back 90 degreed for easier connection using timurs rom and automate launcher I got rid of the ash tray and made a wireless charging deck there, and a dual usb car charger tucked under the shifter trim to power the tablet and the wireless charger looks pretty clean, works beautifully Sent from my STV100-1 using Tapatalk Did you use any electric tools like dremmels or anything? How did you wire the Nexus to your car stereo and power? Any videos I should watch? Link to comment Share on other sites More sharing options...
Andy_Mac Posted October 24, 2016 Share Posted October 24, 2016 Did you use any electric tools like dremmels or anything? How did you wire the Nexus to your car stereo and power? Any videos I should watch? No video's, but there's a couple of threads worth glancing through if contemplating doing it yourself. http://forum.liberty.asn.au/viewtopic.php?f=22&t=29716 http://forum.liberty.asn.au/viewtopic.php?f=22&t=21888 http://forum.liberty.asn.au/viewtopic.php?f=22&t=30312 http://forum.liberty.asn.au/viewtopic.php?f=22&t=30559 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
abaig97 Posted October 25, 2016 Author Share Posted October 25, 2016 the only electric tool I used was a dremel to trim the existing bezel, as for wiring it up, its just powered through a usb car charger, and a long aux cord going into the the center console, the rom installed on the nexus takes care of powering it on or off when the car charger is turned on Sent from my STV100-1 using Tapatalk Link to comment Share on other sites More sharing options...
freaksavior Posted October 25, 2016 Share Posted October 25, 2016 the only electric tool I used was a dremel to trim the existing bezel, as for wiring it up, its just powered through a usb car charger, and a long aux cord going into the the center console, the rom installed on the nexus takes care of powering it on or off when the car charger is turned on Sent from my STV100-1 using Tapatalk I got annoyed with that. I carefully ground the solder grounding pads and then moved it upwards. http://i.imgur.com/bju20gn.jpg From there I glued it so it wouldn't break the contacts in case of a cable being yanked. For the data and power I used a USB hub. Since a car runs DC, and that hub takes 12-22v you can wire a usb hub straight to the car without the need for a regulator. I used one anyway to clean the power. The mini ups I have will also do that. This is the hub I used. https://static.amazon.com/EasyAcc-Aluminum-SuperSpeed-Charging-Y44BUS/dp/B00IHWBRL4 PCB http://i.imgur.com/rGFC44r.jpg Power Supply http://i.imgur.com/6CMyF7f.jpg Just take out the hub, and mount it behind the nexus 7 across the metal bar, and then cut the cord off the brick and wire it to your cig lighter. Since this is switched accessory, it turns on the nexus automatically when enabled through the kernel. I would also remove the battery since it's going to cause a rapid drain in high heat. There's a youtube video on this. You could even pickup a mini itx ups for a replacement battery like I did from the dc-mini company. http://i.imgur.com/yQDdPwX.jpg http://i.imgur.com/ONCtXKn.jpg This would prevent it from shutting off once you remove the lithium battery. Link to comment Share on other sites More sharing options...
abaig97 Posted October 25, 2016 Author Share Posted October 25, 2016 battery literally just crapped out on mine today, im going to ditch a use it without one Sent from my STV100-1 using Tapatalk Link to comment Share on other sites More sharing options...
freaksavior Posted October 25, 2016 Share Posted October 25, 2016 There's a JDM dash bezel in the FS section. It fits with minor modification. You could angel your usb port if you've got a steady hand, and hard wire the USB port for power. Link to comment Share on other sites More sharing options...
WRX USA Posted October 26, 2016 Share Posted October 26, 2016 There's a JDM dash in the FS section. It fits with minor modification. You could angel your usb port if you've got a steady hand, and hard wire the USB port for power. Are you talking about this? http://legacygt.com/forums/showthread.php/ca-norcal-h0017ag915-05-09-double-din-nexus-size-257132.html At first I thought you meant a RHD dash which obviously wouldn't fit with minor modification since you'll have a steering wheel and pedals on the passenger side. Link to comment Share on other sites More sharing options...
freaksavior Posted October 26, 2016 Share Posted October 26, 2016 Are you talking about this? http://legacygt.com/forums/showthread.php/ca-norcal-h0017ag915-05-09-double-din-nexus-size-257132.html At first I thought you meant a RHD dash which obviously wouldn't fit with minor modification since you'll have a steering wheel and pedals on the passenger side. It fits. There's a small gap to the right because of that, but if you trim the vent pieces, you can fit it in nicely. http://i.imgur.com/rIeRgRk.jpg Y'all should check out solidxsnake setup, he also uses it. Link to comment Share on other sites More sharing options...
WRX USA Posted October 26, 2016 Share Posted October 26, 2016 It fits. There's a small gap to the right because of that, but if you trim the vent pieces, you can fit it in nicely. http://i.imgur.com/rIeRgRk.jpg Y'all should check out solidxsnake setup, he also uses it. I know if fits, I've got a couple of them. To be clear, a "dash" is the entire dashboard whereas a JDM bezel is the piece that fits in the top of the dash. That is why your post initially confused me. Link to comment Share on other sites More sharing options...
freaksavior Posted October 26, 2016 Share Posted October 26, 2016 Ohh my bad. I see I put jdm dash and not bezel. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 27, 2016 Share Posted October 27, 2016 I'll quote myself so it may inspire others in an alternative route to install a nexus 7. Alright, FINALLY here is a quick video I made. I claimed it'd be less than 10 mn but it ended up being 10mn . Link to comment Share on other sites More sharing options...
BMCracer Posted August 4, 2018 Share Posted August 4, 2018 I got annoyed with that. I carefully ground the solder grounding pads and then moved it upwards. http://i.imgur.com/bju20gn.jpg From there I glued it so it wouldn't break the contacts in case of a cable being yanked. I know this is an old thread, but this picture is exactly what I need to do, make the miniUSB tab come out of the back of the case rather than out the edge. I've got the back cover off, can you please explain exactly what to do now to get the tab bent at 90 degrees. Do I need to take the board out ( if so how 'because I've taken the 6 little screws out but the board is still stuck in there ) or can I do it in-situ? Is it just a case of unsoldering the 4 little blobs ( 2 on each side ) and then bend the miniUSB up carefully? Do those 4 little grounding blobs need to be reconnected afterwards ( otherwise how does the miniUSB get grounded? ). Link to comment Share on other sites More sharing options...
freaksavior Posted August 5, 2018 Share Posted August 5, 2018 Well if you're good with a soldering iron, you can just unsolder it and then gently pry it up. I'd use epoxy to resecure it later in case you pull the cord out. I used a dremal and cut off wheel and gently ground down the ground solder points until it lifted. Just be careful. I ruined one, and had to buy a second piece off flebay. Link to comment Share on other sites More sharing options...
BMCracer Posted August 6, 2018 Share Posted August 6, 2018 Thanks man. Do the ground points need to be reconnected? Otherwise something is missing it's ground? Link to comment Share on other sites More sharing options...
freaksavior Posted August 6, 2018 Share Posted August 6, 2018 I haven't had any issues with it since i've done this. Link to comment Share on other sites More sharing options...
Ahmed Shawky Posted March 1, 2019 Share Posted March 1, 2019 http://uploads.tapatalk-cdn.com/20161004/e8c5ae32ec45b64ef67998e9c27dec06.jpg Sent from my STV100-1 using Tapatalk How can i communicate with You i have alot of questions please Can u give me ur whatsaap no. Link to comment Share on other sites More sharing options...
Ahmed Shawky Posted March 1, 2019 Share Posted March 1, 2019 Anybody still act 9n this post please can help Link to comment Share on other sites More sharing options...
Ahmed Shawky Posted March 1, 2019 Share Posted March 1, 2019 There's a JDM dash bezel in the FS section. It fits with minor modification. You could angel your usb port if you've got a steady hand, and hard wire the USB port for power.Where can i find it plz Sent from my ONEPLUS A5010 using Tapatalk Link to comment Share on other sites More sharing options...
