leighos Posted October 3, 2016 Share Posted October 3, 2016 Not sure if your US models do this, but when I unlock using the remote, all door locks unlock, then immediately lock again with exception of the drivers door. To get the other doors to unlock I have to push the unlock button twice again! Could be just a euro thing but its damn annoying and there must be a way to disable it? Sent from my ZUK Z1 using Tapatalk Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted October 3, 2016 Share Posted October 3, 2016 1st press = driver's door unlocks 2nd press within a second press within a second or so = remaining doors unlock Link to comment Share on other sites More sharing options...
leighos Posted October 3, 2016 Author Share Posted October 3, 2016 Thank you! The other doors unlock, lock, then unlock... Those door motors will wear out pretty fast running like that won't they. Sent from my ZUK Z1 using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted October 3, 2016 Share Posted October 3, 2016 On 1st press of the keyless remote the drivers door unlocks. On 2nd press all the doors unlock. The only way the doors unlock by themselves is if the key is in the ignition and a door is open and you lock them. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
Ellesedil Posted October 3, 2016 Share Posted October 3, 2016 I've never noticed my doors unlocking and relocking on the first press. Link to comment Share on other sites More sharing options...
leighos Posted October 3, 2016 Author Share Posted October 3, 2016 I've never noticed my doors unlocking and relocking on the first press. There's either something wrong with mine or its a euro spec thing, my friend has a JDM wagon and that unlocks drivers on first press and all other doors on second. Sent from my ZUK Z1 using Tapatalk Link to comment Share on other sites More sharing options...
ChrisCrash Posted October 3, 2016 Share Posted October 3, 2016 Has it worked that way since you got the car? Im wondering if the remote got sat on or dropped and the rubber of one button is somehow hitting both underneath. Link to comment Share on other sites More sharing options...
leighos Posted October 3, 2016 Author Share Posted October 3, 2016 I will take a look at the remote, but its don't this since I bought it in March Sent from my ZUK Z1 using Tapatalk Link to comment Share on other sites More sharing options...
aperson Posted October 4, 2016 Share Posted October 4, 2016 Check for an aftermarket security system or car starter under the dash (if you don't have a fob for one already). Could be something someone did to just "make it work". Those are the only things other than a defective factory component that would cause this. My 2011 3.6r unlocks just the drivers door with first press then all with a second press. Link to comment Share on other sites More sharing options...
leighos Posted October 4, 2016 Author Share Posted October 4, 2016 Both factory key fobs appear normal, and no aftermarket equipment fitted. I'm going to try find someone who has a 2009 diesel the same as mine and see if its a 'feature' or a fault. Already checked a JDM 2.5 model and that works as expected. Sent from my ZUK Z1 using Tapatalk Link to comment Share on other sites More sharing options...
