bbabiuk Posted October 1, 2016 Share Posted October 1, 2016 Has anyone done this? I have an '11 Legacy 3.6R with the 6 CD changer. No nav. It also has the silly lookin Bluetooth connect unit. I want to swap out my radio. I'd like to put in a factory nav deck. (Just to keep it looking stock). That and I can get an unlocked unit cheap on eBay. As well I can get the correct trim piece that goes around the stereo/climate controls on eBay. My million dollar question. Is everything there to make it work? I assume it's mostly plug and play. However my concern is the antenna for the Navi. My vehicle not having Navi right now makes me think I need to find one. Anyone try this. Should I just go the aftermarket way? Sent from my Nexus 6P using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted October 1, 2016 Share Posted October 1, 2016 I would go aftermarket. I am assuming you don't have the Hamon Kardon system. The factory nav system is not a good one there are much better options in the aftermarket. You should also look into adding a backup camera, I do believe the harness is in the trunk you just need to wire it in. It has been done, search the forum using google, and try to get a hold of svxdc he makes all kinds of harnesses for Subarus he can tell you exactly what you need for your goals. Link to comment Share on other sites More sharing options...
matts_pats Posted October 5, 2016 Share Posted October 5, 2016 Get a pioneer NEX. Svxdc is a ghost. However his old website has tons of info. Crutchfield also has everything you need Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
