Dinka Posted September 28, 2016 Share Posted September 28, 2016 My Legacy is a 01 NA 2L EJ201 5MT Legacy L That I got used and I'm the second owner and it has a fuel economy of a V8 Engine 4kmpl!! Ill tell the history It had some issues about 9 Error Codes Were there when I did the scan and all of them very fixed and no more error codes Things I replaced and serviced. 1. Fuel Regulator and the Dampers ( The Return line was Blocked and I replaced that as the Pressure was as high as 80psi on the fuel line after that if this was feeding excessive fuel that must have been eliminated now fuel pressure sits at 40psi that is normal. 2.Injectors were Ultrasonic cleaned and checked for leaks and passed. 3.Spark plugs checked and re gapped. 4.Throttle body cleaned inside out. 5.Front and Back O2 sensors replaced. Only Thing done was I Decat the car because the Cat was already rattling because it was broken inside now it's straight through It has a very bad hesitation on cold starts or if I start the car after parking it for 3 hours it is so bad it sometimes stalls I have to rev it to like 2500 or 3000 to get it out of this slope in my house to the road and it smells like unburnt fuel most of the time! it has very bad low end torque its hesitant to go from a stop light even in 2nd gear it jerks a bit and then starts to go. I will post these values I got off my Live scanner at idle let me know if they are ok. http://imgur.com/92v5q4Y Link to comment Share on other sites More sharing options...
Dinka Posted September 28, 2016 Author Share Posted September 28, 2016 Link to comment Share on other sites More sharing options...
RumbleRumble Posted September 28, 2016 Share Posted September 28, 2016 Have you changed the fuel filter? or plug wires? Link to comment Share on other sites More sharing options...
Dinka Posted September 29, 2016 Author Share Posted September 29, 2016 Yes I have Link to comment Share on other sites More sharing options...
I3eXa Posted September 29, 2016 Share Posted September 29, 2016 so no more codes now or do you still have some showing? Do you have a full custom exhaust and what size piping? checked the PCV system? Link to comment Share on other sites More sharing options...
Dinka Posted September 29, 2016 Author Share Posted September 29, 2016 so no more codes now or do you still have some showing? Do you have a full custom exhaust and what size piping? checked the PCV system? No more codes no mods on the Exhaust stock just the cat and resonators are taken off it... what about the PCV mate ? Link to comment Share on other sites More sharing options...
RumbleRumble Posted October 1, 2016 Share Posted October 1, 2016 I've never heard of PCV causing bad gas mileage, only oil burning. Do you have a pinging? Maybe carbon build up? Run 91 or 93 for a couple of ton with some seafoam or something similar. Link to comment Share on other sites More sharing options...
Dinka Posted October 4, 2016 Author Share Posted October 4, 2016 Replaced cat found one locally ! for 35$ Instantly more power bottom end to top! Dono about fuel economy I shall report back with that unlike other idiots who abandon threads after finding the problem and resolving it I hate that! Link to comment Share on other sites More sharing options...
bhazard Posted October 4, 2016 Share Posted October 4, 2016 That last pic from your scanner. Look at the fuel trim ...not sure what the 3 means, probably one of the cylinder banks. I believe that -28% means the ECU is detecting a very rich condition and trying to pull that much out of the fuel map. Check that number again now that you've "fixed" it. Link to comment Share on other sites More sharing options...
Dinka Posted October 4, 2016 Author Share Posted October 4, 2016 That last pic from your scanner. Look at the fuel trim ...not sure what the 3 means, probably one of the cylinder banks. I believe that -28% means the ECU is detecting a very rich condition and trying to pull that much out of the fuel map. Check that number again now that you've "fixed" it. Like I said I'm Yet to check the Fuel economy but definitely the Bottom end bogging down and hesitation is gone so lets see how the economy is and then we can tell if it's 'Fixed' the issue. And I will check that as well. Link to comment Share on other sites More sharing options...
RumbleRumble Posted October 4, 2016 Share Posted October 4, 2016 Fuel filter is a 26$ish good thing to replace if you havnt done it or done know when it was done. Link to comment Share on other sites More sharing options...
bhazard Posted October 5, 2016 Share Posted October 5, 2016 Make sure you've disconnected the battery and reset the ECU too Link to comment Share on other sites More sharing options...
Dinka Posted October 5, 2016 Author Share Posted October 5, 2016 Make sure you've disconnected the battery and reset the ECU too Didn't do this since the Sensors were replaced is this really necessary ? I'll do it tomorrow Link to comment Share on other sites More sharing options...
Dinka Posted October 5, 2016 Author Share Posted October 5, 2016 Fuel economy is the same 4KMP F*** Liter I'm fedup at this point I will reset the ECU tomorrow and see Link to comment Share on other sites More sharing options...
RumbleRumble Posted October 5, 2016 Share Posted October 5, 2016 How many miles to a tank do you get? 300 is average for mostly city driving. Link to comment Share on other sites More sharing options...
Dinka Posted October 6, 2016 Author Share Posted October 6, 2016 I pump 10 liters as soon as the fuel light comes on the car and run it till the light comes back on Link to comment Share on other sites More sharing options...
Dinka Posted October 6, 2016 Author Share Posted October 6, 2016 Does anyone know where the fuel lines go from on the BE5 ? I suspect its a leak from some where! I can't seem to find the Fuel lines under the car. Link to comment Share on other sites More sharing options...
bhazard Posted October 6, 2016 Share Posted October 6, 2016 You cannot accurately gauge fuel economy from partial fillups! Fill the tank all the way, reset trip meter, drive til it's low. And then fill it again. Divide the distance driven by the amount of fuel it takes to fill again. If you go 300km and it takes 15L to fill, that's 20km/L. Or 5L/100km. And yes you replaced sensors and your fuel trims were way out of wack, you MUST reset the ECU. Link to comment Share on other sites More sharing options...
Dinka Posted October 6, 2016 Author Share Posted October 6, 2016 You cannot accurately gauge fuel economy from partial fillups! Fill the tank all the way, reset trip meter, drive til it's low. And then fill it again. Divide the distance driven by the amount of fuel it takes to fill again. If you go 300km and it takes 15L to fill, that's 20km/L. Or 5L/100km. And yes you replaced sensors and your fuel trims were way out of wack, you MUST reset the ECU. I reset the ECU today took the Negative off for a couple of min and pressed the Brake paddle a few times how big is the Legacy B4 fuel tank ? Link to comment Share on other sites More sharing options...
bhazard Posted October 6, 2016 Share Posted October 6, 2016 64 liters is what I found Link to comment Share on other sites More sharing options...
bhazard Posted October 6, 2016 Share Posted October 6, 2016 http://www.auto-data.net/en/?f=showCar&car_id=16175 Link to comment Share on other sites More sharing options...
RumbleRumble Posted October 6, 2016 Share Posted October 6, 2016 Fill the car up. Reset trip, drive it until you need gas, divide mileage by how many gallons took you to fill up = mile per gallon and you will also get mileage per tank. Do it a couple of times to find your average. Link to comment Share on other sites More sharing options...
