kent55 Posted September 24, 2016 Share Posted September 24, 2016 I noticed a wet spot under where I park and looked underneath to find a Goldish color liquid dripping off the transmission. It's dripping off next to the transmission drain plug, but the front Passenger Side half shaft is wet. It's a 2007 2.5i stick shift. First, Is this oil and trans fluid? Second, could this be the half shaft going bad or a seal somewhere inside the transmission needing replaced? I think this half shaft has been replaced when the clutch was replaced 3 years ago. (100,000 miles on car) http://i774.photobucket.com/albums/yy26/kent55/be1d275c-54c1-4ee6-9580-48beeb5f70fb.jpg You can see a Gold drip just right of the drain plug http://i774.photobucket.com/albums/yy26/kent55/IMG_20160923_192145844.jpg This is the Passenger side http://i774.photobucket.com/albums/yy26/kent55/IMG_20160923_192805544.jpg This is the Driver's side http://i774.photobucket.com/albums/yy26/kent55/IMG_20160923_192317594.jpg The Passenger side half shaft Link to comment Share on other sites More sharing options...
apexi Posted September 24, 2016 Share Posted September 24, 2016 Looks like the passenger side axle seal is leaking. Unless the fluid is new, or newer, I would drain the transmission and replace the seal. Driver side and passenger seals are different, and have different part numbers. I've been able to install axle seals with my thumb, but it's hard to do, and almost break my thumb every time. I plan to get these tools at some point, to make things easier. http://legacygt.com/forums/showthread.php/crr-oil-seal-installer-and-axle-protector-254753.html *oh also, before anything else I would check your transmission fluid level. Link to comment Share on other sites More sharing options...
kent55 Posted September 25, 2016 Author Share Posted September 25, 2016 I didn't realize I could see the CV shafts so easily from the top side. And love the dip stick. http://i774.photobucket.com/albums/yy26/kent55/IMG_20160925_132454554.jpg http://i774.photobucket.com/albums/yy26/kent55/IMG_20160925_133155660.jpg Link to comment Share on other sites More sharing options...
kent55 Posted September 25, 2016 Author Share Posted September 25, 2016 Are these common to go bad? Link to comment Share on other sites More sharing options...
kent55 Posted September 27, 2016 Author Share Posted September 27, 2016 I had the seal replaced today with the Subie brand. Thanks for the TIP. That was it. Link to comment Share on other sites More sharing options...
