BoxerLove Posted September 14, 2016 Share Posted September 14, 2016 Hello all, Scratching my head here. Yesterday coming home my radio, and HVAC stopped working. The Driver information center above the radio was blinking "ACC." I turned the car off and back on, the ACC at some point turned to "ERR" and now it doesnt do/show anything. The buttons on the driver information center do not work. The Radio does not turn on or respond to any button presses, The HVAC also does not turn on or respond to any button presses. My interior lights do not work and the key fob does not work anymore. The only other thing i changed was my tune map. Working with my tuner he sent me a new map to try and log for him. Which i wouldnt think was related? I first started to look through the fuse panel's for blown fuses. I found fuse 24 on the interior fuse panel was blown. I replaced the fuse and it hasnt changed anything. The only modification done to my radio is the Jazzy aux in mod. Up untill this point i havent had any issues. Stuck here with no heat or radio! Any other threads i seen related to this i could not find an answer on. Reaching out for help! Thanks a bunch Link to comment Share on other sites More sharing options...
BoxerLove Posted September 14, 2016 Author Share Posted September 14, 2016 FIGURED IT OUT! The engine bay fuse box has the 20 amp fuse listed as a spare. The fuse right next to it IS NOT A SPARE! Derp. Put a 20amp back in there and boom. Everything started working again. Honest mistake I guess Link to comment Share on other sites More sharing options...
Dre617 Posted September 15, 2016 Share Posted September 15, 2016 lol Good work, was just about to say double check those fuses because after that is multimeter time and that is not always fun Link to comment Share on other sites More sharing options...
