huntzmax Posted September 11, 2016 Share Posted September 11, 2016 Im having a pretty bad vibration only when I accelerate it's really bad from about 45-75 mph then it gets quieter and less vibration around 80 mph. I'm guessing it's a bad axle or drive line. Im going to rotate my tires and see if that does anything to it. Doubtful though. Any threads you guys can direct me to, or info would be greatly appreciated. I'm in salt lake and may need to take it somewhere for a proper diagnosis if you have a place you recommend. Thanks in advance. Link to comment Share on other sites More sharing options...
I3eXa Posted September 11, 2016 Share Posted September 11, 2016 Vibration in the steering wheel or what? Sent from your bedroom closet ]-.-[ Link to comment Share on other sites More sharing options...
huntzmax Posted September 11, 2016 Author Share Posted September 11, 2016 The steering wheel doesn't vibrate. It just feels like it's in the drive train and something is off balance. Link to comment Share on other sites More sharing options...
Cincy05LGT Posted September 11, 2016 Share Posted September 11, 2016 Prop shaft carrier bearing Motor mounts Axles Wheel balance Flywheel balance Link to comment Share on other sites More sharing options...
