drunkinmonk Posted August 29, 2016 Share Posted August 29, 2016 Will this work on an outback? I searched and had a hard time finding my answers. Anyone running this set up? Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
whitetiger Posted August 29, 2016 Share Posted August 29, 2016 +35 is too low of an offset generally. you can fit them with a narrow tire like a 225 or so, but you are gonna want a wheel with offsets in the mid to high 40's Link to comment Share on other sites More sharing options...
Rhitter Posted August 29, 2016 Share Posted August 29, 2016 Will this work on an outback? I searched and had a hard time finding my answers. Anyone running this set up? Sent from my SM-N920V using Tapatalk In general yes, it should fit, with cutting. However, you are going to have to do fender work to get it to fit. Read through Rebourne's thread to get an idea of what it will take. Although, he is only at 18x8+35 in the rear. http://legacygt.com/forums/showthread.php/rebournes-06-obxt-build-thread-243318.html My OBXT build Link to comment Share on other sites More sharing options...
drunkinmonk Posted August 29, 2016 Author Share Posted August 29, 2016 I had a chance to buy some with 3 set of used tires for 625 but I don't want to hack up the fenders to get them to fit right. Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
Rhitter Posted August 29, 2016 Share Posted August 29, 2016 I had a chance to buy some with 3 set of used tires for 625 but I don't want to hack up the fenders to get them to fit right. Sent from my SM-N920V using Tapatalk If you do, it will look awesome. But, you will have to hack the / roll / cut the fenders and might have increased wheel bearing wear. My OBXT build Link to comment Share on other sites More sharing options...
Acerguy Posted October 4, 2016 Share Posted October 4, 2016 I know it's a stale post but depending on how low you are....well, here is THE MATH based on the stock OB 17x7x48 wheel running a 225/55-17. I'm on LGT struts/shocks and there is only about 6mm of clearance between the tire and the spring perch on the front. Going to 18's will be...interesting. Link to comment Share on other sites More sharing options...
Rhitter Posted October 4, 2016 Share Posted October 4, 2016 Yep, have to go with a lower offset wheel just for that reason. Or switch to a smaller tire size. My OBXT build Link to comment Share on other sites More sharing options...
