whlightning Posted August 26, 2016 Share Posted August 26, 2016 Hi gang looking for some advice. I have a 02 h6 llbean outback with 152,000 on it. A few months ago it started missing, check engine light is on and codes are cylinder misfire codes. I have changed plugs as well as several coil packs trying to fix it and so far nothing. I have also checked and cleaned all grounds . Unrelated I have also recently changed the alternator and battery. Took it to a guy that works at a Subaru garage today and he put it on his computer which shows more, he says the timing is changing up to 50 degrees and that the chain is stretched. Does that sound correct? Anyone really good with these things in the western pa area? Thanks Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted August 26, 2016 Share Posted August 26, 2016 Bad timing can cause misfires.Your right around the mark where alot of H6 guys have this problem. A chain(s) can stretch but probably wont break. Most likely one of your Chain Tensioners went bad(cause they do wear out). If you do want to replace every part under the timing cover you are looking at 550$ in OEM Subarus parts. Have someone take the cover off and inspect whats going on before you blow a ton of money. Do it sooner than later. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted August 26, 2016 Share Posted August 26, 2016 check compression. H6 is chain driven and at 156K it is possible that timing could be off. also check injector pulses to make sure one isn't open or shorted (high current draw) Link to comment Share on other sites More sharing options...
