kent55 Posted August 22, 2016 Share Posted August 22, 2016 So I'm not familiar with this car yet and needing to replace the front blinker bulbs. On the driver side does the battery need to come out and the intake on the right side? Link to comment Share on other sites More sharing options...
Fasemelta Posted August 22, 2016 Share Posted August 22, 2016 Yup you got it Link to comment Share on other sites More sharing options...
apexi Posted August 23, 2016 Share Posted August 23, 2016 I avoid disconnecting the battery on my non-turbo legacy, if that's what you have. You might be able to pull back the fender lining in front of the wheel, and replace the bulb that way, I can't remember. It's no big deal if you disconnect the battery, but the car will drive weird for a few days afterwards, and might almost stall when stopping, for example. Link to comment Share on other sites More sharing options...
kent55 Posted August 25, 2016 Author Share Posted August 25, 2016 Okay. I can try the fender liner method. I'm installing LED lights in them and also been looking for the blinker flasher unit. It looks like it is very high above the fuse box under the dash. Does that sound right? And is it grey? Link to comment Share on other sites More sharing options...
Fasemelta Posted August 25, 2016 Share Posted August 25, 2016 I have a link to the relay install on my for sale thread. My relay was a pain to remove from the box, it was stuck on there good http://legacygt.com/forums/showthread.php?t=254882 If you're looking for some nice rear led's I have em! Link to comment Share on other sites More sharing options...
