Thors Twins Posted August 16, 2016 Share Posted August 16, 2016 Have an opportunity to buy stock used-but-good struts/srpings and anti-sway bars w/ links from 2011 WRX. Anyone know if these components are a direct fit for the subj. vehicle and would there be a need to change control arms, etc? thnx in advance Link to comment Share on other sites More sharing options...
Unsp0kn Posted August 16, 2016 Share Posted August 16, 2016 The fronts might not clear depending on your setup and the perch is about 1/2" lower. Search a bit, there's a whole bunch of info on Koni setups for our cars. Link to comment Share on other sites More sharing options...
Thors Twins Posted August 16, 2016 Author Share Posted August 16, 2016 anti-sway bars, at a minimum? Link to comment Share on other sites More sharing options...
GTEASER Posted August 16, 2016 Share Posted August 16, 2016 It will all physically fit and bolt up with the exception of the front sway bar and front tophats if those are included, but none of it is really worth it. The springs are really no stiffer than your stock ones, the rear shocks are a little better but not by much, the spring perch on the front struts is 1/2" lower than the Legacy perch and may cause clearance issues with Legacy size tires, and the rear sway bar is a 16mm, exactly what your car has stock. Also, it will be a little bit of a crap shoot as to the resultant ride height when installing those in a Legacy. I wouldn't bother with any of it. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Thors Twins Posted August 16, 2016 Author Share Posted August 16, 2016 Thank you, sir! Link to comment Share on other sites More sharing options...
