Stevh0 Posted August 14, 2016 Share Posted August 14, 2016 Now before you say, why would you want to use the delta dash monitor in your 3.0, there are a couple of reasons... 1. I have it. 2. coolant temps 3. knock correction (though probably not a big issue on the NA motors) So, after moving the Delta Dash monitor from my hawk STI, to my Foz XT, I was sure it would work in my 3R. I does not, even though they apparently do support it. Question, has anybody every run the monitor in their 3R? Link to comment Share on other sites More sharing options...
Perscitus Posted August 15, 2016 Share Posted August 15, 2016 Or just grab a copy of BtSsm and a BtSsm dongle (or use a Tactrix OP v2 if you have one already) and... Intake Temp Coolant Temp Engine Oil Temp ATF Temp (if applicable) Fuel Temp OCVs, VVTs, Total/Learned Timing, FKC, FLKC, IAM, Learned Views, etc. Works with 3.0Rs, 3.6Rs Link to comment Share on other sites More sharing options...
Stevh0 Posted August 15, 2016 Author Share Posted August 15, 2016 I do have Btssm too lol. I dont have a Btssm dongle, so i'd probably have to buy one. I'd probably buy a Tactrix though. Any proof that the Ecutek actually works with the 3.0 or 3.6? Link to comment Share on other sites More sharing options...
Perscitus Posted August 16, 2016 Share Posted August 16, 2016 Ecutek? Not sure what it has to do with gauges or logging SSM parameters. The BtSsm dongle should work well for you, get Tactrix only if you plan to flash your ECU/TCU, work with a tuner, etc. Link to comment Share on other sites More sharing options...
Stevh0 Posted August 16, 2016 Author Share Posted August 16, 2016 I've owned about 4 scoobie and had to sometime beg borrow and steal a tactrix to change something here or there. I think it's finally time to just buy one. Lol Vagcom with an otg cable also works fine with btssm. Link to comment Share on other sites More sharing options...
