Scubaboo Posted October 12, 2018 Share Posted October 12, 2018 Gotcha, thanks! Link to comment Share on other sites More sharing options...
Scubaboo Posted October 13, 2018 Share Posted October 13, 2018 I sent the pics in this thread (thanks BBPeik and GTEASER) to the supplier. He recommends a Subaru NA engine application rad he has, still all aluminum and thinner too at a bit over an inch thick (Stock rad is 16mm thick). No more hole to plug at the passenger side corner. Hopefully it clears the charge pipe. Looks to have a few extra mounting brackets but the important bits look similar. Link to comment Share on other sites More sharing options...
devilsinu Posted October 13, 2018 Share Posted October 13, 2018 Great post and good replies. Maradyne makes some ultra-thin fans that I installed on a 2015 wrx and there was enough room to do the timing belt without taking out the radiator. Link to comment Share on other sites More sharing options...
Scubaboo Posted October 14, 2018 Share Posted October 14, 2018 ^First I'd heard of Maradyne, thanks for the mention. They look to be well regarded along with Spal. I wonder how reliable aftermarket fans are? I havent seen many builds that go to the trouble of replacing the OE ones. Link to comment Share on other sites More sharing options...
FLlegacy Posted October 14, 2018 Share Posted October 14, 2018 ^First I'd heard of Maradyne, thanks for the mention. They look to be well regarded along with Spal. I wonder how reliable aftermarket fans are? I havent seen many builds that go to the trouble of replacing the OE ones. The OEM ones have the advantage or being reliable and having the two speed option, even my local shops who do very expensive builds reuse the stock fans. I think making a new fan mount might be a worthy consideration, since the plastic is what really takes up space there. Link to comment Share on other sites More sharing options...
Scubaboo Posted October 14, 2018 Share Posted October 14, 2018 ^that's what I've heard as well, that they are more reliable. I didnt know they could not go multi-stage, won't power supply from the car dictate that? I think low profile mount is a good idea. Link to comment Share on other sites More sharing options...
FLlegacy Posted October 15, 2018 Share Posted October 15, 2018 ^that's what I've heard as well, that they are more reliable. I didnt know they could not go multi-stage, won't power supply from the car dictate that? I think low profile mount is a good idea. No the wiring in the car supplies either a low speed power or high speed, but AFAIK they are both 12v, maybe two different windings in the motor or something of that nature. Link to comment Share on other sites More sharing options...
utc_pyro Posted October 15, 2018 Share Posted October 15, 2018 It puts the motors in series or parallel to do the multi speed. 3.0r/3.6r did it with a PWM module. The bigger reason to stick with OEM fans is they are higher performance, full stop. Only reason to go aftermarket is if you do something like turbo a 3.6r and need the room for a charge pipe or something. Link to comment Share on other sites More sharing options...
Scubaboo Posted October 15, 2018 Share Posted October 15, 2018 Pyro, thanks for that. I learned about PWM fans diagnosing my BMW lol. I see our fans here are 2 wires so I knew they werent PWMs, and wondered how the Subie fans varied speeds. Link to comment Share on other sites More sharing options...
Scubaboo Posted October 15, 2018 Share Posted October 15, 2018 Just put the rad on. Fit perfect with no mods at all. Fans shifted back a bit but nowhere near enough to worry about hitting anything. This is with a 26mm thick rad, stock is 16mm. I did the thermostat while the rad was out too. Put in an OE STI 78 deg thermostat and new OE thermostat housing gasket. Link to comment Share on other sites More sharing options...
DEAD SE-RIOUS Posted March 28, 2019 Share Posted March 28, 2019 Just put the rad on. Fit perfect with no mods at all. Fans shifted back a bit but nowhere near enough to worry about hitting anything. This is with a 26mm thick rad, stock is 16mm. I did the thermostat while the rad was out too. Put in an OE STI 78 deg thermostat and new OE thermostat housing gasket. Nice. Has anyone else tried this with no modifications at all? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Scubaboo Posted March 29, 2019 Share Posted March 29, 2019 Nice. Has anyone else tried this with no modifications at all? Sent from my iPhone using Tapatalk Sorry, tried which? Link to comment Share on other sites More sharing options...
DEAD SE-RIOUS Posted March 31, 2019 Share Posted March 31, 2019 Sorry, tried which? Anyone else have no modification like you. I’m bone stock, so I’m hoping I too won’t have to modify anything. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Scubaboo Posted April 1, 2019 Share Posted April 1, 2019 Oh ok. It will come down to sourcing the right rad. Most of the STI rads are 30+mm thick and that is simply too thick to fit without mods. Maybe a Forester rad will work better. The rad I used is speced for both 2010-up Legacy and 09-up Forester IIRC. Link to comment Share on other sites More sharing options...
Fabsx Posted April 4, 2019 Share Posted April 4, 2019 Been running a mishimoto for over a year. Had some issues with the stock fans. Ended up grabbing a 16” and a 14” slim “Hayden” fans from the local part store. Grab a sheet of aluminum to fabricate a fan shroud for them. The fans do stick out past the radiator, especially the 16”. But I wanted the extra flow capacity to lower temps. Dont have any clearance issues or anything now. These fans are actually better than stock and dropped my temps alot in the summer with the fmic. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
DEAD SE-RIOUS Posted April 5, 2019 Share Posted April 5, 2019 Oh ok. It will come down to sourcing the right rad. Most of the STI rads are 30+mm thick and that is simply too thick to fit without mods. Maybe a Forester rad will work better. The rad I used is speced for both 2010-up Legacy and 09-up Forester IIRC. Which one do you have? Model info? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Scubaboo Posted April 5, 2019 Share Posted April 5, 2019 Which one do you have? Model info? Sent from my iPhone using Tapatalk Link to my install thread with more info, hope it helps. https://legacygt.com/forums/showthread.php/another-all-aluminum-radiator-option-5th-gen-gt-276124.html Link to comment Share on other sites More sharing options...
Zee199969 Posted May 17, 2019 Share Posted May 17, 2019 Now someone needs to try a koyorad [emoji13] quoting a really old post, but the Koyorad VH091662 fits perfectly: https://legacygt.com/forums/showpost.php?p=5896685&postcount=1254 My "Build" Link to comment Share on other sites More sharing options...
