FtsTexx Posted August 4, 2016 Share Posted August 4, 2016 The Wifey has an 05 stock Outback, and she asked that I stay doing a little personalization for her. So far it's been decals, light film and lil stuff. I'm needing to tackle some issues first, and I'll post em as they come up.. Steering probs- When turning left, there is a loud clack clack clack, that speeds up with acceleration. Can you help me diagnose it? (Will post vid) Next. When locking the car from the door. The alarm chirps like normal, but the hatch doesn't lock. If you open it, well everyone looks at you as you scramble to turn it off.. twice.. in the same parking spot [emoji28] [emoji379] Any ideas? There's more to come, but like I said.. priorities!! http://uploads.tapatalk-cdn.com/20160804/bf3b3227f5092f4da6edb26b7a3108e4.jpg Sent from my SCH-I545 using Tapatalk Link to comment Share on other sites More sharing options...
WRX USA Posted August 4, 2016 Share Posted August 4, 2016 Sounds like front wheel bearings might be causing the noise. The most likely problem with the hatch is that the wires controlling the lock are broken. You will probably have to replace the harness in the hatch. Link to comment Share on other sites More sharing options...
SCASEYS Posted August 4, 2016 Share Posted August 4, 2016 clacking is the AXLE I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
BXR6 Posted August 5, 2016 Share Posted August 5, 2016 Yes, clicking sound is probably the CV axles. Common issue. There are huge debates on which ones work best for replacement. Most say don't go aftermarket, aftermarket ones reportedly cause weird vibrations. But subaru replacement ones are very pricey. I found some low mileage originals in a junk yard for $30 each. You can tell original ones by one end being painted green. But now those are going bad and i'm debating trying some rockauto axles. Link to comment Share on other sites More sharing options...
