CYKZ1 Posted August 4, 2016 Share Posted August 4, 2016 So I bought a nrg srk 105h and also a 100h which says it's for all legacy years. Neither fit after I removed the steering wheel. I put the steering wheel back but not the airbag, turned on the car to make sure everything was normal but brake light started blinking and the slipping tires icon came on too.. great right. Anyone else attempt to install one and have success? It's a 2013 2.5 6 speed manual. Link to comment Share on other sites More sharing options...
Unsp0kn Posted August 4, 2016 Share Posted August 4, 2016 If you turned the car on without the airbag plugged in then it likely tripped the airbag computer out. Have you tried disconnecting the battery, letting the system drain, reinstall the airbag and reconnect the battery? Link to comment Share on other sites More sharing options...
CYKZ1 Posted August 4, 2016 Author Share Posted August 4, 2016 Will try that today Sent from my SM-J700T using Tapatalk Link to comment Share on other sites More sharing options...
