jonnyt88 Posted August 3, 2016 Share Posted August 3, 2016 Looking at an 08 outback. I was curious if you get the head unit/ hvac from an 09 limited , would it be easier to wire into an after market amp/sub? I ask this because the HK setup wires to an amp so maybe the wires in the back will make this easier and cheaper than the JDM route. I also ask because there is an 09 legacy in the local scrap yard I could pull the headunit/hvac from. Link to comment Share on other sites More sharing options...
