RumbleRumble Posted July 29, 2016 Share Posted July 29, 2016 So I know my 01 came with the smaller Rotors but I have a pair of the bigger WRX size. Will they fit the front without causing problems with the dust shield? It's a GT-L so I have the 16in snowflakes. The caliper or brake pad size didn't change from 00-01 to 02-04 just a little different style Link to comment Share on other sites More sharing options...
RustyRuu Posted July 29, 2016 Share Posted July 29, 2016 i think you need 17 for most brembro brake swaps, but im sure it depends on the wrx years also, im thinking 02-05 might be small enough for 16s. i have the 5 spoke/10 spoke (depends on how you think of it) wheels from a wrx on my car and they are only 16s. what year did the bigger brakes come from? Link to comment Share on other sites More sharing options...
Sara32013 Posted July 30, 2016 Share Posted July 30, 2016 Not sure if it helps or not but I accidentally ordered a set of GT rotors once when I was doing a brake job on an '07 Legacy. The rotors fit fine on the studs but the caliper wouldn't mount in place. I don't believe you can just slap bigger rotors on any car without changing the "caliper mount" for lack of a better term Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted July 30, 2016 Author Share Posted July 30, 2016 They are the bigger size for the Legacy The L being the smaller size and the GT being the "wrx" size Link to comment Share on other sites More sharing options...
Regardie Posted August 8, 2016 Share Posted August 8, 2016 The rotors should fit but you will need the bracket from the WRX calipers as well, or one from an 03-04 Legacy. The caliper is the same, the bracket moves the caliper further out to accommodate the larger diameter rotor. Link to comment Share on other sites More sharing options...
