jeannie Posted July 18, 2016 Share Posted July 18, 2016 All right guys I am back with another issue with my lovely Subaru. The other day my car started just fine no problems driving down the highway all of a sudden my car start sounding like a lawnmower https://vimeo.com/175169280And it makes kind of a popping noise when you're Revit up. Here's a video I hope you guys can help me out thank you for your time. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
KRM Posted July 18, 2016 Share Posted July 18, 2016 Sounds like a tractor, with a bad exhaust leak. I found it easy to find those leaks by having a cigar lit and putting out smoke around the area it's coming from. Should see it right away. And it beats burning you're hands feeling for it. Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted July 18, 2016 Share Posted July 18, 2016 if that is an exhaust leak it should be easy to spot because it must be large. It really sounds bad, almost like a rod knock. Any CELs associated?? Link to comment Share on other sites More sharing options...
wesleyCrowbar Posted July 18, 2016 Share Posted July 18, 2016 I just had the same thing. Check the connections to the UP and check the passenger side header Link to comment Share on other sites More sharing options...
jeannie Posted July 18, 2016 Author Share Posted July 18, 2016 I don't think it sounds like a rod knock. It does have a cel on but I don't think it's because of this. Because it a p0171 (lean code) but they might be associated but I had the code before this. I just got my rack fixed on Thursday then this happened and Saturday so idk. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Phate Posted July 18, 2016 Share Posted July 18, 2016 Just use your vape and blow clouds around any areas that might leak. Link to comment Share on other sites More sharing options...
jeannie Posted July 18, 2016 Author Share Posted July 18, 2016 Yeah I will have to do something like that. I have all ready put 280 in to the car this month because my steering was bad I was hoping it would be fine tell at least next month lol Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
