acdcrockme Posted July 14, 2016 Share Posted July 14, 2016 HI there recently my 07 legacy 25i had a light issue where when the driving lights are on the back light work noreally but when I get on the brakes only the window and right light brighten to signify braking what could cause this does anyone know or how to fix this? Link to comment Share on other sites More sharing options...
apexi Posted July 14, 2016 Share Posted July 14, 2016 I'd like to help, but I'm not sure I fully understand what you're saying. All of your brake lights illuminate normally when your lights are on When you hit the brakes, only 2 of the 3 lights get brighter. I'm pretty sure our brake light bulbs have 2 filaments inside, one which causes the lights to light up normally, and the 2nd filament kicks in when you hit the brakes to make the lights brighter. You can try replacing the left brake light bulb, it sounds like one of the two filaments might be broken. The bulb part number is 7443, but 7443LL works too, LL signifies long life, which are preferable in my opinion. *Just to confirm, they are dual filament bulbs http://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage//299/large/5080162_syl_7443LL_pri_larg.jpg Link to comment Share on other sites More sharing options...
acdcrockme Posted July 22, 2016 Author Share Posted July 22, 2016 that solved it thank you allot this can be closed now Link to comment Share on other sites More sharing options...
