Stevh0 Posted July 8, 2016 Share Posted July 8, 2016 I have a light vibration at 20 mph when the car is under load. It worsens when I hitch a trailer. Nearly like an unbalanced propshaft. It eases up and goes away at higher speeds. Balanced the rims and tires today, just incase. This is my 5th scoobie and the first to have the issue. Could it be shaft related? Link to comment Share on other sites More sharing options...
Stevh0 Posted July 11, 2016 Author Share Posted July 11, 2016 I've inflated my tires a little more and the vibration is a little less. The tires are a little worn and could have some flat spots. But coming back to the U-JOINT. Is there a way to inspect it? Should it have any free play on it? Link to comment Share on other sites More sharing options...
